Hi All,
I have been researching for a number of days/weeks in order to select a smart charger.
Just when I think I find a solution, I read other forums etc.. and start questioning again....
My requirement is for a pair of heated gloves, which I have got already but need to change the controller, battery type and rating as one glove is u/s.
So what I need is to charge the battery packs for each glove simultaneously and have a balanced charge (in both glove battery packs).
The battery pack for each glove is a 2S 8.4V with BMS (Samsung 2600mAh 2S1P IRC1865026J). I wanted the BMS for discharge.
As the gloves are being used together, they need to be re-charged at the same time.
I was looking at a ISDT T6 BattGo, but not sure if this will work or if I need a ParaBoard, or not, or a dual charger etc....?
I want a solution that is portable for travel (in luggage), so don't want anything too large or complicated.
Would appreciate any suggestions, comments....
Regards
Regards
