Sensitron SMCV6M060-025-1A, 120V, Sensorless FOC controller
fellow
Sweden, EU.
Any info about where to buy this controller and how much it costs?
Dimensions: 92mm x 44mm x 27mm (3/4 the volume of the S06S controller :shock: )
Maximum recommended battery voltage 120V.
Maximum peak/spike voltage 250V
Recommended motor current 50A
Shutdown output current 74A
Design peak current 80A
Features
Sinusoidal Sensorless Speed Control
Vector Drive FOC with Space Vector PWM
Available Power stages use IGBT’s rated to 1200V or MOSFET’s rated to 600V
75A peak phase, 800V steady state operation
Top speed of 74,000+ RPM; 4 pole motor
Re-configurable firmware
Programmable PWM 7-20Khz
Isolated RS232 interface
Programmable digital Control lines
Digital Tach and Direction output via RS232
Smart gate drivers with de-sat protection
Boot-strap powered high sided gate driver
Integrated phase current sensors
DC bus voltage sensor
Protection
DC Bus Overvoltage
DC Bus Undervoltage
DC Bus Critical Detection
Phase Loss Detection
Zero Speed Detection
Operating Baseplate Temperature
-40°C to 85°C
Power Requirements
Bus Voltage to 800 VDC
+3.3V +/-5%
+5.0V +/-5%
+15V +/-10%
Webpage, not showing the "A" models: http://sensitron.com/motorcontrollers.aspx?type=4.5
Pdf with "A" models included: http://sensitron.com/data_sheets/5127.pdf
