Boyntonstu
I want to limit the chairing to the largest gear.
The shifter will not lock nor will it pull the chain guide far enough to move the chain onto the largest gear.
I can cut away all the shifting elements and place the chain on the gear,
Is the chain guide necessary to prevent fall off?
If the chain guide is required, I will have to figure a way to force it into the correct position.
The rear shifter is not working, Broke. Dead!
I almost alway us the smallest gear so with that in mind the large chainging and the 11 tooth rear is pretty well lined up.
This is about the semi-recumbent.
AAMOF the chain is stuck on the rear gear and until I replace the shifter, I can live with it.
