- Joined
- Nov 10, 2022
- Messages
- 1
I've got a 1500w Voilamart rear hub motor. It was working.
I was swapping the external controllers from 1000w to 1500w, in the process I shorted the throttle wires, all of them together at once. (I was putting metal male/female adapters and spaced on taping them up before introducing battery voltage). Dumb, I know. It was a 6-pin thumb throttle.
Anyhoo I got a new throttle as I assumed I had burned up that one, and scrapped the 1500w controller. So now I had a brand new throttle, and a controller that was unaffected by the short, that I knew to be in working order hooked up.
The switch on the throttle shows power but pressing the thumbpiece does nothing.
So I determine from this that the hall sensors in the hub motor must have been affected. No visible signs but I had a spare hall sensor board and replace the whole thing. The motor works! Although I had a feeling it was going to fail. Rode for a few miles, got to a hill and it cut out a few times, started working again, and then completely died. Back to throttle showing power but pressing does nothing. What the hell is going on???
