nebriancent
hello all
i have one main problem since i started running my e-bike
i had no way to run 12v led lighting off of my main bat as i have been running 48v nom voltage and durring full charge the battery it reading 55v so i could not use any 12v automotive led lighting on my bike unless i ran off of one of my 4 batteries and i have found this to be a bad idea
i started off thinking i will just keep an eye on the one batt and swap out wen i notice a voltage drop in comparison to the other batts ... but im sure we all know how that turned out
so the solution i came up w/ is by no means a new idea... and it is verry wastfull at higher currents but ITS CHEAP
and i know for menny like myself on a first ebike that dose come first untill we figure out if the ebike sceen will work for us
another solution i am noting is the use of small battery powered lighting made for bikes but i dont realy like the idea of replacing batteries
so i will give you the tools needed to create you own xv-12v converter
(i will build one complete w/ pictures over the next couple of posts here)
first thing you need is a staring voltage (how many volts is my battery pack)
2nd thing you will need is a target voltage (12-14v)
parts list
1 @ 14v 10w zenner(overkill but i like to play safe) i use pn 1n2978b
1 @ resistor (wattage and value dependant on build)
1 @ npn transistor (i get mine out of dead computer power supplys)
first off i suggest lower then 10w ttl draw from this circuit so 10 / 14 = .71 amp
i also suggest you build the circuit for more then you plan on using eg build for 1 amp draw
(side note) do not at any time short the positive and neg leads together you will destroy the circuit and give the load full voltage
the calculations
what you can draw is heavily dependant on the zenner transistor and resistor you use
first you need to find the dc gain and max power dissapation for the transistor
once you have the dc gain figured out divide the ttl amperage buy the gain and we now have a target volt ref amperage input
for exaple you may have a dc gain of 1000 so for say 1 amp draw you would need at least 1ma or .001 amp draw from the zenner/resistor pair
but remember over shoot over build and it will last
so now we need a easy way to figure out the zenner and resistor value (i use http://www.calculatoredge.com/electronics/zener.htm )
just input max volt(fully charged bat pluss a lil extra for safty)
min volt (battery is fully drained voltage)
zenner voltage(you target voltage)
and load current in ma (.001 of a amp)
next post i will show how to put these components together and i should have some pics of a fresh build
and how to find info on the trasistor ect
ps please please please use a heat sink ... if you dont you could burn your circuit and anything connected to it
parts list
the calculations
