ebike4healthandfitness
- Joined
- May 19, 2012
- Messages
- 1,180
What is the slowest wind direct drive hub motor available?
MadRhino said:When you buy direct from the manufacturers, you can order the winding that you want. If it is very unusual, you will have to wait but the cost will be the same.
ebike4healthandfitness said:What is the slowest wind direct drive hub motor available?
Balmorhea said:Use the voltage range that gets you the best prices and variety in controllers and batteries. That's 36, 48, or 52 volts.
Balmorhea said:The only advantage to using more than 52 volts is that makes it easy to get higher power and speed from motors that were designed for lower voltage. If you're not hot rodding, there's nothing to be gained there.
ebike4healthandfitness said:20 mph (or 28 mph with pedaling) top speed is not hot rodding.
ebike4healthandfitness said:@Balmorhea,
The advantage of the high voltage (with the slow winding) is torque and efficiency.
Getting 20 mph (without pedaling) could be done with low voltage and a faster wind motor......but it wouldn't climb as well.
Balmorhea said:ebike4healthandfitness said:@Balmorhea,
It's just not true. Watts are watts. 750W at 24V/40A and 200 RPM doesn't climb any better than 750W at 48V/20A and 200 RPM.
ebike4healthandfitness said:Here is a 24v system (using the faster wind Clyte H3540 laced to a 29" wheel) vs. a 48v system (using a slower wind Clyte H3525 laced to a 20" wheel) on a 7% grade
Balmorhea said:ebike4healthandfitness said:Here is a 24v system (using the faster wind Clyte H3540 laced to a 29" wheel) vs. a 48v system (using a slower wind Clyte H3525 laced to a 20" wheel) on a 7% grade
The winding isn't proportional to the voltage, isn't proportional to the free speed. Changing the wheel diameter renders the comparison useless. Smaller wheels are better for hub motors, but worse for humans riding them.
If you want to get the very best from a hub motor, then use a small wheel-- but it will beat you up. And that's a totally different factor than voltage. Same wheel, same power, same unloaded speed, you'll get the same efficiency with 72, 48, 36V.
ebike4healthandfitness said:dogman dan,
There actually is a 72v 20amp controller?
