...and holy cr*p what a difference it made!
I've got a Goldenmoter 500 watt, 36 volt rear motor setup. I did the zener diode trick to the standard controller (I haven't modified the LVC yet, but will eventually get around to it), and upgraded the phase wires down to the axleshaft with 16 gauge. (I have some 16 gauge teflon insulated wire that I will eventually use, opening the motor up and replacing the phase wires all the way, but that will be a project for this winter.) I'm still using SLA - it's cheap, and works fine for experimenting for now.
Running 36 volts, top speed was between 17 and 20 mph (checked with the stationary radar "your speed is" sign at work - I don't have a speedometer yet).
I have not checked top speed at 48 volts yet (they move the sign around; I have to find where they put it and make a run by it), but the bike moves much faster on the flat, and doesn't slow down on the (slight) uphills around here. The motor gets slightly warm to the touch, but it did that at 36 volts anyway, so it doesn't seem to be having any problems handling the higher voltage.
All in all, 48 volts is *sweet*!
