[SOLD][CAN only] Grin Tech ebike bundle: Phaserunner V2, CA3-DPS, Analogger, DAUX + extras
irf23
🧲 New user
Cleaning out a 2018 Grin build. Everything came directly from ebikes.ca and an invoice is available on request. All items sold as-is, untested (I no longer have a bike to test on).
Canada-only shipping from Calgary. Local pickup welcome.
Bundle: $380 CAD
  • Phaserunner V2 controller with MT60 battery connector, 6-pin CA cable, 5-pin hall cable, 3-pin throttle cable
  • Cycle Analyst 3-DPS (original, not the WP8 rework)
  • Stainless steel steer-tube mounting plate for the CA
  • Cycle Analogger (microSD datalogger for CA3)
  • DAUX 3-button auxiliary controller
  • V2 front torque arm
  • 1mΩ CA stand-alone shunt, unterminated
  • Mornsun Q3-4805CBD-6A isolated DC-DC (~18 to 75V in, 5V at 6A out, 30W)
  • Grin right-hand half-twist throttle, 140cm cable
  • Dual ebrake levers (L+R, single 4-pin JST, 140cm cable)
Compatibility note, worth reading if pairing with a modern Grin motor:
The V2 Phaserunner predates the speed/thermistor demux circuit that showed up in V4 and later. With a modern L10 or Z9 motor (All-Axle v3, etc.), the combined speed+temp signal cannot be split into the CA-DPS's separate inputs without a custom demux circuit, opening the motor to separate the signals at the source, or skipping motor temp and using an external spoke-magnet speedo into the CA. Confirmed by Grin support. Full discussion here: [link your ES thread].
TL;DR: ideal for rebuilding a 2018-era Grin setup, or for someone comfortable with the speed/temp workaround. Not a drop-in for a brand-new All-Axle v3 build expecting thermal rollback out of the box.
Prefer PM. Payment by e-transfer.
SOLD
