Last week I received and installed an EM3EV Rear wheel, 8t Mac kit, with, 50 v, 13ah, battery, and the 25 amp 6fet 3077 infineon controller. It’s great, but I have a few technical questions.
I’m using the CA3, which came from Em3EV without a USB plug, so hopefully I won’t need to connect it to anything but the bike.
Question one: why, in my main CA3 display, do my watts read out as a negative number? For example -14, or -12? It’s the same for A.H. I’m getting readouts like 0.4ah when I still have ten miles of actual range left. How can I fix this?
Question two: Is there a way to resume my cruise speed? I’ve got bike trails all around my house that cross streets about every three hundred yards and I would like to easily reset cruise. With my half-twist, being a bit twitchy, and the trails being a bit bumpy, it takes a lot longer than the 2 seconds I have the CA set to, to actually reset cruise.
Question three: what’s the best way to lengthen battery range and reduce speed with the CA3? Should I set a speed limit, should I set a power limit? If so, which one? I know that this is a pretty noobish question, but I’m no engineer, and I find that the CA3 has too many options for a simple guy like me.
Question four: What’s the best way to treat my battery well? Wait until it’s depleted and do a full charge? Charge every time I ride the bike? I can make it to work and back on the battery’s 22-mile (that’s how far I get before the battery indicator goes blank—I have yet to run it until it actually dies, though) range, but I wonder if I should also charge at work—just for the battery’s sake.
