someone do a conversion on this!!!
monster
do you think an X503 would be too much?
What's that, a 30" front? :shock:
Hmm, get a 5305 and custom lace it in the front wheel... Remove the pedals since there's no freewheel, and weld on your own pegs for footrests.
And... the ridiculously short wheelbase just means it can make tighter corners at high speeds, right? :D
the wheel base could easily be extended by about a meter or so. maybe put another seat on it?
If you made the main-tube the battery case, then you'd have a winner.
you could put the same kind of hubmotor in each wheel, and then you'd have a hillclimber motor (rear) and a high-speed motor (front).
