jhendrickson
- Joined
- May 14, 2015
- Messages
- 10
I have an S12S controller with the LCD-3 display. I've decided on going with a 5V USB LED handlebar light with an on/off switch. That means I just need to wire in a female USB connector to get 5V from my controller. I am not using the PAS or speed sensor connectors so those seem like viable 5V sources to me.
Problem is that when I wire those up and try to use them it makes the motor inoperable. Here's what happens:
1. I turn the display on - throttle works fine.
2. I turn the light on - throttle is either unresponsive or goes for a second then cuts out.
3. I turn the display off - nothing works.
4. I turn the display on again - throttle works fine again until I try to use the light.
I'm guessing that the system gets confused when a higher current is pulled by the sensor connector when the light is turned on.
Any ideas? Has anyone been able to use these sensor connectors for 5V power? Other suggestions for getting a 5V power source out of this configuration?
Thanks!
joe
Thanks!
joe
