vwhammer
I took my rims and hubs to the bike shop to have them laced up and got a call a little later from the shop expressing concern for the spoke hole diameter in the hubs vs the spoke gauge/diameter.
I have a Q128H and a Q100H and the spoke holes measure about 3.3mm and 3.5mm respectively.
This is big enough to fit a 10 gauge spoke through.
All the bike shop had was 14 gauge and they were afraid that it was going to pull the head through the holes in the hub.
This is understandable since the head on a 14 gauge spoke is only about 3.85mm
So I guess my question is now, what gauge spokes are people running with these motors.
Clearly I am not going to run 10 gauge spoke and from what I can gather even a 12 gauge spoke will require me to drill my rim so the nipple will fit.
not really interested in running washers or anything like that at the hubs because that seems a little hokey to me.
I would probably rather re-drill the rim to make the 12 gauge spokes work before I do too much else.
So anyone that is running either of these motors, what did you use? Are your holes in the hub as big as mine?
Will 13 gauge stuff work safely?
