totals
I've worked on cars for years. The most important tool that is often not used by "home jobbers" that will solve this issue: A tork (torque) wrench.
Use a proper tork wrench to tighten the nuts to the proper specification !
People mistakeningly believe that if you use all of your force to tighten a nut as much as you can that it will never come lose. Wrong. Doing that, will actually stretch the bolt and weaken it. The risk is bolt failure, or the nut slowly spinning off.
Use a tork (or torque) wrench to set the nut to the maximum foot pounds of torque recommended for the nut and bolt and that nut will never come lose.
I also have tork arms on my bike, but they should be considered a back up, not a replacement for a properly tightened nut.
Finally, I would suggested testing the tightness of the nut, again using your tork wrench, regularly to make sure it is not coming lose. Because the tool tells you how tight the nut is, you can guage if something is going wrong.
I'm in Canada, but I know you can buy this tool from any auto shop. Here is the one I use: http://www.canadiantire.ca/browse/product_detail.jsp?FOLDER%3C%3Efolder_id=1408474396672989&bmUID=1230156319380&PRODUCT%3C%3Eprd_id=845524443257163&assortment=primary&fromSearch=true
This will sure take you all out of the dark in wondering if the bolts are on tight or going to spin off at any minute !
Hope this helps. I really don't like hearing about people getting hurt. These bikes are a lot of fun, and i ride over 80 km/hour regularly with a front hub motor; and do so safely knowing all the nuts and bolts are tight !
Rory
Rory
