nugget_handler
🧲 New user
I need to get a 48V vehicle to work with up to 4 72V battery packs. The packs are equipped with a BMS which already supports mating up to 4 of them together. I am mostly concerned with the DC-DC step down problem.
I found these ready-made converters which seem to have functionality I need, but I am not sure if I will need anything else:
I think I will also have to design a PCB with the input protection, output protection, power management/control, monitoring/interface circuits, as well as the thermal management components.
Am I missing anything? Any guidance on how to start this project? Thank you in advance!
- Dc 60V 72V TO 48V 30A 1440W Dc Dc Converter IP68 Step Down Module, 12V
- 72V to 48V 60A 2880W DC DC Step Down Converter Voltage Regulator w ACC Switch
- تيار مستمر محول تيار مستمر 52-90 فولت 60 فولت 72 فولت إلى 48 فولت تيار مستمر محول تنحى باك 1A 2A 4A 10A 16A 20A 48 فولت تيار مستمر الجهد المنظم لجهاز السيارة - AliExpress
- DC/DC converter 72V to 48V, 550W • DWE
- DC/DC converter 72V to 48V – 500W • DWE
- 72V to 48V 30A Step Down DC DC Converter Regulator 72 Volt to 48 Volt 1440W Buck Transformer Power Supply for Cars Toys
- Multiple Alibaba Options
- SD-1000-MEAN WELL Switching Power Supply Manufacturer
