I have a strange BMS issue.
I change a bad BMS with a new one. The bad BMS outputs correct voltage, but as soon as it is loaded, it drops the voltage.
The new one outputs 0.45v so something is bad with it.
I change to another new BMS. I test the new one before soldering it and it outputs correct voltage.
I solder everything and after, it starts behaving strangely. I have to disconnect and connect the load several times until I get proper voltage. I can load the battery pack (4A), but only sometimes.
I take the previous new BMS I changed first time and try it on another battery pack, and viola! It works!
I’ve checked the balancing wires many many times, and they are correct. I measure the voltage directly on the BMS connector with my super thin probes.
All cell groups are balanced.
ATM, they are all around 4v.
I checked the increment, and all add upp correctly.
4,8,12,16…..v
The polarity is correct.
I’m suspecting bad cell wires, but they all measure correctly on the connector.
What can it be?
4,8,12,16…..v
What can it be?
