Ok, so..
This spintend is kind of a pain in the ass to setup. There's some uncertainty in the documentation and tons of articles to read to figure out what to do from scratch. There's also tons of parameters.. reminds me of working with an ASI ( at least it can auto detect! )
Pros:
- This series controller would be badass for a 2WD setup and seems to have ABS and traction control, makes me want to build a 2 geared hubmotor setup..
- It basically has every controller/vehicle feature you could dream of.
- Diagnostic lights are awesome and i wish every controller had these.
- Looks and seems well built
Cons:
- Documentation is scattered among blog posts, videos, and some unlisted wiki with no domain name, initial learning process is bad and only the devoted will make it through.
- Included throttle wire ( red, black, green ) is pinned incorrectly, negative and positive reversed, you have to pop the pins out and redo them.
- No idea if the 12v connection even needs to be hooked up, i did it anyway, had to make a cable becauese the bag didn't include one.
- I bought the suggested thumb throttle and brake lever. Throttle works great, brake lever is cheap and uses a tiny switch ( a little worrysome, i think a hall based switch would be safer/more durable )
- Can't get regen working no matter the settings but the ebrake lever does respond and cut off the throttle. I have to contact tech support already.
- The EDC v3 adapter has no protective backing or coating to prevent it from a short, you have to DIY a solution. I'm using zip ties and foam. This thing deserves a plastic case.
- The finished assembly is a mess of wires and the packaging of it is lacking even more now with the EDC v3 adapter.
- I can't get the suggested procedure to calibrate the brake and throttle to work, maybe this suggestion was for an older version/doesn't apply anymore.
- They don't make a heatsink for this model so without DIYing one together, i suspect the continuous current handling is much lower than advertised.
I think this VESC is very nice ( feature and quality wise ) but i think they have some refinements to make to make it newbie recommendable. The learning curve is steep and some unnecessary DIYing is needed, and it looks like a science project.
Will get impressions on the road in the near future.
