Allex
Allex said:Looks like Sur-Ron changed their 10A chargers.
These are made to be mounted inside the bike, but works just as good as an external one.
The 300A kelly on the left in comparison, and It is tempting to swap out original controller to it!
Now, who want to see the battery?
I got to tell you, these guys mean business. This is the best built battery on the market to date for this kind of money!
Everything is water proof, really well thought-out and high quality components everywhere.
Supra x connectors on the drain side
cnlinko industrial connectors on the charge side, waterproof and very high quality.
No cheap XLR/Anderson connectors here. They really put their heart into this battery!
The only thing I would improve is having thicker nickel strips, but this is only needed if you want to suck more than 85A from the original cells. And you cannot do this because the stock BMS itself is 85A rated.
So you probably end up swapping BMS as well once you start mod this bike with diff. controller.
https://endless-sphere.com/forums/viewtopic.php?f=28&t=89902&p=1358016&hilit=xlr#p1358016
The updated battery have different holders and better cell connection - a lot more nickel.
There is actually space for 4 more cells so you can build a 180 cells battery using original holders and have a 20s9p pack
If you like glue, here is what you can fit within the actual cell holder, 109 on each level gives you 218 cells, thats a 20s11p pack if you add 2 more cells on top. Using Sanyo GA you get 72V38Ah
If you are brave and use minimal protection you can fit another row, thats additional 30 cells and gives you 248 cells a potential 21s12p if you can fit 4 more cells.
