Can't wait to get the Sur-Ron.
Here are some things I can't wait to check out on the Sur-Ron and also compare to my current bike. I will be comparing the Sur-Ron to one of the best built, (in my opinion), hub motor bike out there, using what I consider the best frame on the market, and all the best components.
My Qulbix Q76R has top notch components, max-e, high end - suspension, motorcycle seat, the narrowest frame on the market, foot-pegs, MXUS turbo 3K, 3.2KWH battery pack. This bike amazes me every time I take it out on how smooth and powerful it is, balanced, easy to maneuver and handle because of its thin frame. I only use 8KW power but the Max-E is set with PWR settings to give ridiculous fast acceleration.
1) First Inspect the wheels to see how true and how tensioned the spokes are before riding. checking trueness first with a dial indicator and park tools tension meter before using the bike, Then I will pre-tension on all the spokes and see how much out of true and how much the tension changes on each spoke.
2) How much of a difference the rear suspension works compared to my hub motored bike. Going over objects fast with my hub motor bike would violently through up the rear, the front would smoothly go over anything. Curious to see just how much of a difference the suspension is without that 25lbs hub motor sitting at the center.
I never rode a mid-drive bike so I really don't know if the rear suspension is just never as smooth as the front, or if its because of the 25lbs hub motor.
3) How powerful the Sur-Ron is compared to my hub motored bike. My 8KW hub motored bike has plenty of power and will climb anything no matter how steep, will accelerate quickly to 55MPH. Will be interesting to compare this to the Sur-Ron. If the Sur-Ron can beat it out at speeds below 20MPH, I will honestly be surprised. Allex says the Sur-Ron is like riding a 14KW bike at lower speeds so I'll be able to see if that is true or not.
I believe anything over 20MPH my hub motor bike will be much faster, this is because of the Max-E and pushing 8KW.
4) How the wider Sur-Ron frame compares to my 76mm wide Q-76R frame. I just love thin frames, makes a huge difference in the feel of the bike and also makes the bike feel more balanced.
5) Top speed, I'm hoping the Sur-Ron can at least get up to 50MPH using the X controller. My bike can get up to 55MPH easily and that is really as fast as I would ever want to go. If the Sur-Ron can't get to even 50MPH, that won't be great for passing cars.
6) Overheating, I usually like riding in the hottest summer days, over 90 degrees, and I ride always full throttle. My hub motor bike is always overheating, but my custom cooling keeps it in check. Will be interesting to see if the Sur-Ron really doesn't overheat on hot summer days when pushing the bike hard, with constant hill climbing or stair climbing.
Even with my custom cooling, if I climb up a steep hill my motor temps will spike to over 120C. Will the Sur-Ron really not spike like this climbing steep hills or stairs. Will be amazing if it doesn't to be honest. Somehow I think I will still be able to overheat it.
7) Seat height, my Qulbix equipped with a motorcycle seat is fairly low, but the Sur-Ron comes in even lower. I like low seats but felt the Q76R height was optimal. Will be interesting to see what an even lower seat height feels like.
8) Front tire size and weight. I use a 26" Duro-Razorback 3" tire and a bicycle rim. While both fairly heavy for bicycle components, still far less lighter than what the Sur-Ron will use for the front wheel. The Sur-Ron will use a heavier motorcycle rim, tire, and tire tube.
It will be interesting to see if this extra weight is noticeable and how it affects the front suspension and feel of the bike.
A 26" bicycle tire is larger than the Sur-Rons 19-2.75" tire. The biking community all love larger tires, saying 27.5" tires are worlds better than 26", and 29" is even better. Will the small 19" Sur-Ron tire be a disappointment?
9) Throttle control. I actually prefer the thumb throttle. I find it gives me much more precise control over the bike and much easier to always have the brake covered while pushing down on the throttle. I also find that when things get really rough, I can clamp down on the handlebars and hold everything tight without having the throttle twist on me.
I do lots of slow riding technical stuff and the thumb throttle gives me very precise control. I know most people hate the thumb, but that is most likely because they always just used a twist throttle and never gave enough time with the thumb.
When I was in Asia and using scooters and stuck using twist, I quickly noticed just how much better the thumb throttle is for precision control and other reasons. I just much preferred the thumb and felt like I lost a lot of control with the twist. While it won't matter much using twist or thumb if you are just cruising down the street. Once you get off-road, doing slow technical stuff, that is where you really need precise control of the bike and where the thumb throttle gives much better precise control of the bike.
I'm going to try and use the twist throttle to give it a chance at first, however, if I notice that I will never get precision control with it, I'm going to switch it over to a thumb throttle.
10) Rear suspension and spring weight. Surprisingly, I believe and could be wrong, nobody here has swapped out their rear spring. This makes me believe many people are using the incorrect spring weight on the rear.
I know from my hub motor bike that going from 450 lbs, to 400lbs, to 350, then to 300lbs, which I use now in spring weight made a huge difference.
When using the 400lbs spring I wasn't even able to use 1/3rd of my rear travel, it was just too firm.
The Fastace shock that the bike comes with can most likely use a FOX 9.5" 3.00" springs (it should fit), so you can easily swap it out for the proper spring weight. Once I get the Sur-Ron I actually have a 9.5" fox spring so I'll know if they can be used with the fast ace shock, I just need to measure it. Many people in the bicycle community use different springs than the shock manufacturer, it doesn't matter as long as the specs are correct.
Here is my current bike I'll be comparing it to, honestly one of the best built hub motor bikes (in my opinion because I know people get offended by me saying this, yes I know your stealth bike is better
) out there using all of the best components. Everything on the Sur-Ron will be compared against this, especially the suspension.
