Rix
100 TW
Looks good with that 3x18 SR241 on the rear, yah, I don't think you will run out of traction
X-Nitro said:Looks good. Let's see..now I want to run a kenda k270 2.75x21 with the sr244, for my black rims; Would like to try it on the rear also but I gotta kill the 244 first.
And
I'll match my front 241 with that 3.00x18 on a set of silver rims, retro.
pipeking said:Hey guys, having problems with my sur ron was wondering if anyone else has had similar issues?
Its cutting out, first few times was from a standstill there was nothing, but now its cutting out at full gas and dying... an unplug battery seems to fix it for about 5km then it quits again.
I have an x controller that was upgrade from the original controller, I am thinking about swapping it back on to see if this goes away.
sucks balls cos its sooo good for stealthing round during this lockdown bs
Offroader said:Nice, yes the high rise bars was probably the best first upgrade you can do on this bike.
For me I think I would go with the x-chain because I don't like to be bothered lubing the chain, I will deal with more friction than bother spraying down the chain with oil.
Rix, I missed it where you decided to go back to the sur-ron. The last thing I remember is you sold your sur-ron to go with that larger electric dirt bike. I see you are back to a sur-ron again.
Offroader said:Did another ride with my new tire and I'm really like thing Shinko 241 tire. I lowered the PSI to around 10 and really rode the bike hard today.
Best part is now I can ride on the street without constantly thinking about how its wearing out my tires. I think one small drawback is that with the lower PSI it seems like the bike may lose a little bit of top speed?
Rix said:Got the 64T on and tested, still hit 38-39MPH, almost as fast as my old SurRon with the 55T sprocket which was a solid 39mph on the radar trailer. Thank you field weakening. And this will loop my ass over backwards if hit the throttle from start. Also got my high rise bars on. This was a huge difference, it makes the whole bike feel just a bit bigger.
Rix said:Can anyone recommend a suspension specialist I can send my Marzocchi forks too for a complete rebuild and revalve? I used Hippie Tech located in Garden City Idaho in the past, but Jerry has closed up shop.
macribs said:Looks good. Two things that might affect the top speed now. First off, that Shinko likely has more rolling resistance then the stock tire. Then that will most likely add up as you keep dropping tire pressure. Put on a tubliss and lower to 3-5 psi and you will like loose even more top speed but will have fantastic grip offroad. And so easy and quick repair should you ever have a flat.
Merlin said:if display shuts also down your bms trips. that would be pretty weird since your X doesnt squeeze much more out of the battery.
which year is your surron?
offroad model or L1e?
Rix said:Had the same issue with mine, it would cut out, but the horn, lights, and display all worked, and it eventually quit working all together, even thought the lights, horn, and display were functioning properly. I eventually learned it was a fet in the controller and Luna sent me a new one. During the trouble shooting process, Luna asked me to disconnect the break safety wires and kickstand to rule out it wasn't something like that. Provided that your instruments are still working, have you disconnected the safety wires?
Yes 1.6" front 2.15" rear, single-butt spokes, cross-3, black nipps. 8)Rix said:X-Nitro said:Looks good. Let's see..now I want to run a kenda k270 2.75x21 with the sr244, for my black rims; Would like to try it on the rear also but I gotta kill the 244 first.
And
Are you going to lace a 21x1.60 rim up front?
X-Nitro said:Yes 1.6" front 2.15" rear, single-butt spokes, cross-3, black nipps. 8)Rix said:X-Nitro said:Looks good. Let's see..now I want to run a kenda k270 2.75x21 with the sr244, for my black rims; Would like to try it on the rear also but I gotta kill the 244 first.
And
Offroader said:Rix said:Can anyone recommend a suspension specialist I can send my Marzocchi forks too for a complete rebuild and revalve? I used Hippie Tech located in Garden City Idaho in the past, but Jerry has closed up shop.
I would consider avalanche suspension, they have a rebuild for that specific fork. I just spoke with them recently and he knows about the sur-ron and has many people contact him about it. He also knows how to deal with the heavier sur-ron and weight distribution. This is also good that he likes the ebikes, because you may get places that hate ebikes and don't want anything to do with them.
I may get my shock and fork rebuilt by them also. It seems they are one of the best in the downhill community, usually recommended as the best place to get stuff rebuilt in the downhill forums.
http://www.avalanchedownhillracing.com/
Specific upgrade for the Marzocchi 888
http://www.avalanchedownhillracing.com/Marz/Marzocchi%20888%2038mm%202008.htm
pipeking said:Merlin said:if display shuts also down your bms trips. that would be pretty weird since your X doesnt squeeze much more out of the battery.
No the display stays on. My bike is an earlier model, the one that didn't have the x controller stock, I got it in 2018
Hi, yea that sounds very similar to whats going on with mine. The lights and horn have been removed but the display stays on. I am positive it can't be any safety switch, as I have removed every one of them, including the tilt sensor. They inhibit fast riding way too much, they all got disconnected in the first week I had it.
I emailed Adam from AE Bikes in Australia, where I got it from, still waiting to hear back from him... did I read somewhere he is actually a licensed motor dealer? 8)
macribs said:Rix said:Got the 64T on and tested, still hit 38-39MPH, almost as fast as my old SurRon with the 55T sprocket which was a solid 39mph on the radar trailer. Thank you field weakening. And this will loop my ass over backwards if hit the throttle from start. Also got my high rise bars on. This was a huge difference, it makes the whole bike feel just a bit bigger.
That 64T looks like a perfect match. Have you gotten a chance to try it in the rough and up still climbs? You on stock controller btw?
Rix said:macribs said:Rix said:Got the 64T on and tested, still hit 38-39MPH, almost as fast as my old SurRon with the 55T sprocket which was a solid 39mph on the radar trailer. Thank you field weakening. And this will loop my ass over backwards if hit the throttle from start. Also got my high rise bars on. This was a huge difference, it makes the whole bike feel just a bit bigger.
Going to take it to "Carol Summit" this weekend and put it through the paces and see how it goes. I rode the green SurRon in this area before, but I didn't have the power to climb a couple of hills. With the X and 64T, I am betting I will.
macribs said:Rix said:macribs said:Rix said:Got the 64T on and tested, still hit 38-39MPH, almost as fast as my old SurRon with the 55T sprocket which was a solid 39mph on the radar trailer. Thank you field weakening. And this will loop my ass over backwards if hit the throttle from start. Also got my high rise bars on. This was a huge difference, it makes the whole bike feel just a bit bigger.
I hope your knee is healing the right way and you are back to old self really soon. Nice to see you are back onto sur ron. That whole Alta situation and how it ended for Alta was sad really. Such a great product ending up on the shelf of can-am. Hopefully they will bring some cool EV's to the market based on the Alta.
Try to make a vid if you manage to climb stuff you previously didn't to try to put that 64T sprocket into context. Are you running the stock controller on the sur ron or have you upgraded?
crazy_dave said:pipeking said:Hey guys, having problems with my sur ron was wondering if anyone else has had similar issues?
If you have already eliminated the brake and kickstand switches........
Get rid of the (tip-over) sensor. I had the same problem after I in stalled my X-controller. I thought I got my sensor right but that damn thing must be touchy. Kept randomly cutting out, eliminated the (tip-over) and have not had a problem since. Its tight under the controller and hard to get everything back exactly right.
Damn, never-mind, just saw that you removed it already. Long shot but....... You said that you have an older model. Is the motor compatible with the X-controller.
