Offroader said:On-road is a lot of fun if you don't have to deal with heavy city traffic. I love riding on the few streets that are like the ones on your trail.
However, Off-road riding is really tough on the body, if you really ride fast off-road you have to be in great shape. It jolts every part of your body, if you have a bad back or neck you can forget about anything hard as you get jolted so hard. It is also very exhausting, I'm in great shape but it takes me a month of off-road riding when first starting up after the winter, for my body to adapt to it and not feel weak afterwards. Its like doing 500 body squats when you go for a ride.
Tommm said:Better to use heat sink plaster. A thermal paste with adhesive properties.
Offroader said:I did think about that when applying it, would I be better with something like a thermal epoxy or thermal adhesive. Maybe, it would make it quicker to install. Then I thought about it and thought, the way I did it makes it completely removable. Not that that really matters. I also didn't have any thermal epoxy and didn't want to wait.
Hummina Shadeeba said:https://essexwire.com/products/endurotemp-260/
Highest temp stuff I’ve seen
Offroader said:Finally rode my bike with the new KTY 84 temp probe.
Highest I could get the motor was 72C-74C. It mostly stayed around 65C-70C. This is with 88F outside air. This is also using 90 amps x battery voltage with a Nuclear 24 fet controller.
I checked the case temp with an infared thermometer, when the temp was 65C inside the motor measured by the temp probe, the case temp measured 57C.
Temperatures also do not spike quickly, even at full throttle and hill climbing.
Does anyone think these numbers are kind of too low? Even the motor case temp outside was 57C and only 8C cooler than inside at the windings?
