Has anyone thought of building a DIY X160 for a little kid?
My kid is 10 and is riding an OSET 20R now. Its small for him riding trails w/ the seat and top speed is low. He rode a friends KLX110 last weekend and loved it. Though he can't shift it, kick start it, or pick it back up when it fell over in a rut.
He complained about the brakes too (drums suck compared to his OSETs upgraded discs.) So wondering about a bigger electric until hes ready to step up to a gas bike w/ a clutch. I don't really like the DC drive in the OSET so I won't upgrade to a 24R. The KLX110 is 27" seat height. The X160 is 30" so probably still a LITTLE bit tall for him. The X160 also costs as much as a SurRon so I'm tempted to just buy another SurRon and lower it to 160 levels (or maybe even a little more for now.) More pros on converting vs buying a X160 is that it would give us a 2nd big battery and could swap the orig parts back on it as he grows.
For the front end, I could retrofit a single crown fork or drop the oem forks in the triple clamps and put travel limiters in. The rear I can find a shorter shock, just get a shorter spring and run w/ less preload, or even make a new shorter shock link. So the suspension parts seem pretty straightforward w/ several options.
The wheels become the next problem. Doesn't look like I can buy the X160 17" wheels anywhere yet though that is probably the simplest/cheapest option. I could buy the 17" supermoto wheels and put dirt rubber on them? I could also make my own, though that would be the priciest option. Front would be easiest as I can lace any rim (like a YZ80/YZ85 17" or YZ65 14") to a matching hole count 20mm hub. The rear is more tricky. The SurRon hub is 36 hole. I found the CRF150 has a 16" 36 hole rear rim. Or even a 12" KLX110 36h rim. Haven't found a 14" yet. Would have to check the tire diameters available to see what combination works.
Thoughts?
