Berd said:On my shipment trackeing email it says 65x30x12”. Weight is shown as 150 lbs (68.5kg)
Was your bike shipped from abroad or within the usa. I am being told I cant get the bike shipped air from overseas to canada
Marksteamnz said:I'm getting the seat reupholstered (bony old arse) so I got it off, but it did reveal a small plug not connected to anything tucked under the seat. LH side of the picture resting on the seat rail and front seat mount. Anyone know what its for?
Jonathan1981 said:#8. Battery charged, do a brief, non agressive test ride, I stayed on eco for a bit until I was sure everything was working properly, nothing smoking, all bolts tight etc. then I hit sport and let the good the good times roll.
Offroader said:Just wanted to comment on something else about the inverted / upside down forks I forgot to mention. When I had my DNM inverted fork (USD 8 model) I was riding over these huge wood chip piles and fell. When the bike was falling and almost on its side, I pushed off of one of the handlebars to stay standing and the leverage with the tire laying on its side twisted or bent the fork.
I was able to grab the fork and and untwist it but it was never as smooth again and I basically threw away $450 dollars. You really have to be careful with those inverted forks as without the cross brace as you can easily twist and bend them. I think the issue is that you can't make them heavy enough like a dirtbike fork for a downhill bike to be stable and strong enough.
Kind of pisses me off still thinking about that, but at least I put back on my Marzochi 888 fork and was so much happier with it.
Allex said:When geometry of the fork is screwed you can tune them up again by sending them to professionals.
I had my Zoch with cross brace tuned in, all models from 2013 have stiction problems, even when new - this when they outsourced the labour to China into SR suntour factory.
Anyway after the tune and alignment of the legs it was a dream fork!
Rix said:Jonathan1981 said:#8. Battery charged, do a brief, non agressive test ride, I stayed on eco for a bit until I was sure everything was working properly, nothing smoking, all bolts tight etc. then I hit sport and let the good the good times roll.
Nice write up Johnny81. The other thing you can do is get a high quality 420 pitch chain and one of Motomoto's 52T or 55T rear sprockets. If body weight is under 210#, go with the 52T if over, go with the 55T. This simple mod really wakes these machines up, and doesn't take much away from top speed. Again nice review and writ up. BTW, just curious about your personally designed machines, kind of sounds like "FX Bikes" stuff, can you PM me, or post a picture of one of your builds?
Rix said:Allex said:When geometry of the fork is screwed you can tune them up again by sending them to professionals.
I had the same issue with the zochs, specifically 2015-2017 models, they all sucked bad with stiction issues. Anyway, I still have one fork that I was going to toss in the trash, you think it would be worth the money to send in for a revalve? I have had good forks revalved and resprung and like them, but they were decent to begin with and didn't have the stiction issues the zochs have/had.
Marksteamnz said:"What do you need to do to get the seat off? It's not obvious which bolts hold the seat on."
It looks like you can unbolt the whole assembly by removing the 4 internal hex large head chrome bolts on the alloy seat support. You can't, there are other bits attached to the seat support, plus the rear light cable. Bother
Rabid said:Well. After deliberating for a while, I finally received my bike a couple of days ago(Had to wait a little longer as they told me there was an orange option!) Took the bike as off road as you can get where I live and the bike was fantastic (I'll try and attach a couple of pictures). However, I also rode on road (to and from work ~12km each way) and at higher speeds (55/60kph+) the motor starts 'pulsing' a bit
What might be causing this? My local specialist is away at the moment, so I thought I'd ask on here (I'm constantly amazed at the amount of knowledge on here: one of the reasons I made the purchase!) The bike is the X Model; full Chinese spec. Thanks for any ideas
fechter said:Marksteamnz said:"What do you need to do to get the seat off? It's not obvious which bolts hold the seat on."
Thanks for posting that. Very helpful.
I figured out it's not too hard to pull the little plastic rivet clips out along the side of the plastic inner fender. Once you get the 6 clips out, the plastic can bend down enough to get access with a wrench.
I used a very small straight bladed screwdriver to pop up the heads on the clips.
Thanks that is a much better way. I thought they were rivets so didn't want to mess with them. Those push clips look off the shelf car panel fixings.
Jonathan1981 said:Here's a pic of my gas bikes,
http://www.dirtforcemotorcycles.com/gallery.html
fechter said:Rabid said:Well. After deliberating for a while, I finally received my bike a couple of days ago(Had to wait a little longer as they told me there was an orange option!) Took the bike as off road as you can get where I live and the bike was fantastic (I'll try and attach a couple of pictures). However, I also rode on road (to and from work ~12km each way) and at higher speeds (55/60kph+) the motor starts 'pulsing' a bit
The pulsing is most likely some kind of feedback loop oscillation in the controller. Since there is no software to play around with, there is not likely to be an easy solution other than replacing the controller. Does it still happen when you are in the Eco mode?
BTW: that's some pretty lush growth in your off road area. Where is that located?
Allex said:Offroader said:Just wanted to comment on something else about the inverted / upside down forks I forgot to mention. When I had my DNM inverted fork (USD 8 model) I was riding over these huge wood chip piles and fell. When the bike was falling and almost on its side, I pushed off of one of the handlebars to stay standing and the leverage with the tire laying on its side twisted or bent the fork.
Jonathan1981 said:Rix said:Jonathan1981 said:#8. Battery charged, do a brief, non agressive test ride, I stayed on eco for a bit until I was sure everything was working properly, nothing smoking, all bolts tight etc. then I hit sport and let the good the good times roll.
Thanks buddy,
Yeah for sure, can play with rear sprocket sizing no doubt... I actually bought a 55T from Kim, but have just been testing the bike all stock and well..... from what I can tell, @ 155lbs, I might not even need it the 55T. I'm pretty satisfied with torque on hill climbs and even lifting the front wheel sometimes so I imagine the 55T might makes things dicy for jibbing and tricking (aka unintended flips).... I'll give it try though and report back.
Regarding the gas bike, yep, FX bikes is what got me started into this 15 years ago.
I built a few and sold a few over the years. Most of the images there are of the second model design, so I called it DHX2.0. Culmination of 10 years of research so it's geo and sus setup is about as good as it gets....full on adult sized bike. Frames made by hand...
if you scroll through, you'll see the original prototype using the Monster forks (with enduro springs) and straight connection, pit bike rear shock, that setup was not enough, bike bottom all the time and wasn't jump-able. Switching to the CR85 shock setup changed the game completely...made the bike WAY more playful and capable. I've never looked back or needed to re-think the suspension. That setup was the PERFECT setup for that style of bike/frame design.
in 2016 I started designing DHX3.0 with CAD, a really innovative frame design, that's still in progress but coming along very nicely. Similar to the Suron in it's aesthetic, it's a VERY polished and finished design. Looks just like something out of a Honda factory, with some cool bells and whistles thrown in. It's designed to be electric start also. Just wish I could show images and my 3D mock up, I have tons of them, but it's just not the right time....
BUT
if you look here and scroll down, you'll see some sneak peak images of the 3.0That bike is going to be INSANE!
https://www.facebook.com/DirtForceMotorcycles/
madin88 said:Allex said:Offroader said:Just wanted to comment on something else about the inverted / upside down forks I forgot to mention. When I had my DNM inverted fork (USD 8 model) I was riding over these huge wood chip piles and fell. When the bike was falling and almost on its side, I pushed off of one of the handlebars to stay standing and the leverage with the tire laying on its side twisted or bent the fork.
My Manitou Dorado Pro did show extreme high stiction after the bike just fell to side. The bike was leant against the wall and it fell to the bottom when i went by and hit the steerer, but luckily after untightening and retightening all bolts again it was working buttery smooth again.
In my case, the fork legs seemed to got twisted a bit inside the crowns which then led to the stiction - nothing was bent, at least it seems so.
This told me that it is very important that those upside down forks are aligned and intalled correct, because otherwise those forks could show an aweful high stiction.
On the dorado for instance it makes a differnce in response caracteristics if you move the legs 0,5mm together or apart on axle and this could happen during installation as there is no end stop on one side.
On this fork it is important that there is no load on it (wheel off the ground) when tightening the bolts which clap the axle.
Added to this i also noticed that it even could make a differnce in response characteristics if you tight the middle bolt of the upper crown (which clamps the 1 1/8" steer tube) to much or to less.
What does it mean? Even the best fork could have poor response characteristics if installed not correct.
Generally speaking of forks, you should be aware that even the smallest variance in alignment of the legs will lead to more stiction.
However that might be only one reason why a fork does not perform well. As Allex posted (the vid) i believe the main issues are manufacturing tolerances. I also owned two Marzocchi 380 forks one was working well and the other was sticky as hell. Shit, its so bad that today it is like a lotary game when purchasing a new fork!
The next time when i buy a new fork i buy 5pcs, compress them with the hands and the one with the lowest stiction i keep, the rest goes back.
Yes thats sad to say, but thats probabaly the best you can do if you spend 1000USD or more for a fork! Maybe the manufacturers learn from that to not sell crap.
Offroader said:How and where did you order the orange X version, I thought they only came in Blue? Even where Sur-Ron sells their bikes in china, on the Tmall webpage, they only have the Blue X version.
Rabid, if you could take close up pictures of the bike in better lighting , would like to see how the orange looks.
Rabid said:Offroader said:How and where did you order the orange X version, I thought they only came in Blue? Even where Sur-Ron sells their bikes in china, on the Tmall webpage, they only have the Blue X version.
The guy I know here told me that there had been a batch of orange bikes made for (I think?) the US. Showed me a piccy and I thought it was pretty cool. In reality, it's a very 'burnt orange' (rather than the KTM vibrant orange I was expecting). I was a little disappointed on opening, but since then (all of 3 days now!) it has grown on meOnce I'm in better light, I'll try and take some better pictures. It's also quite muddy at the moment
(yet to find a good place to clean her
3DTOPO said:Jonathan1981 said:Here's a pic of my gas bikes,
OMG! Dude, I would kill for a snow setup like that for my Sur-Ron. I think that would pretty much be the ultimate snow machine!!!![]()
What a fun project it would be to build one too. I won't have nearly enough time before the snow flies though.![]()
Did you build it, or who built it? If you built it, can you make me one for my Sur-Ron?!?!
