3DTOPO
- Joined
- Apr 11, 2018
- Messages
- 499
Offroader said:I'm not really telling anyone want is the best
Then why did you say this?
Offroader said:Yes, I want to be provocative by saying its the "best"
3DTOPO said:Offroader said:3DTOPO said:Someone who claims to know what the best tires are for everyone should know that.
Missed that, again, link me to a post where I am telling everyone what the best tires are. You keep saying this but are not showing me the posts.
Then you show me a post where I said, "probably the best tire" and that was for my bike I was referring to as I was responding to someone who knows my riding.
You just like to stir stuff up, but then when you get called out you can't show any proof. I read all my posts and am not seeing any posts where I am telling people what the best tire is.
You may lack reading comprehension and that is why you keep reading things incorrectly.
Dude, I quoted you in four different posts essentially saying the same thing. Then when I call you out, you completely contradict your statement made earlier. With your our own words you admitted that you like to say what is best!
So which is it?
And here are more examples. Calling it the "perfect" tire is the same as saying its the best tire.
Offroader said:I'm thinking this may be the perfect tire for the rear of a Sur-Ron, longer lasting on paverment, soft compound, good grip, thick and long knobs.
Offroader said:That being said the Sur Ron stock tires are perfect for the front, they wear very slowly and are light and flexible.
Offroader said:I am finally in the process of building the ultimate Sur-Ron rear wheel, a 18"x3.00" Shinko 241 tire, this is probably the perfect size rear tire you can get.
Offroader said:You lack reading comprehension. Read the stuff you quoted above. Two of them were stating my opinion with using words "this may be" "This is probably".
Offroader said:The front tire on the sur-ron is perfect, I will own up to that one. You find me a lighter weight 19x2.75" for the front. Give me a better alternative? Actually, I would put on a bicycle tire if I could find a close matching size or if the 24" duro razorbacks in 3" were available, assuming that is a similar size to the 19".
Offroader said:I already clarified why I said tires were the best and it wasn't because I was blindly recommending a tire for everyone like you keep saying. Not going to keep going back and forth with this.
Offroader said:For the front tire, at least for me, it is the perfect tire in that the Sur-Ron tire doesn't wear out at all. Is light weight. Has soft tread compound. It is also 2 ply which makes more sense for these light weight bikes, especially for the front.
Offroader said:Let me get this straight, you are running a M403 19" 70/100 size front and rear? What size rims are you using?
Offroader said:I believe this tire is discontinued so this would be a M203 now?
X-Nitro said:I bought the 10.5" Jade coil for the rear, dimwitted granny riders don't need this type of shock :thumb:
Offroader said:X-Nitro said:I bought the 10.5" Jade coil for the rear, dimwitted granny riders don't need this type of shock :thumb:
Did you notice any improvement over the stock shock?
Any reason you went with the jade coil over the FOX DHX2.
I'm leaning on the FOX DHX2.
efMX Trials Electric Freeride said:best surron tires?? :wink:
[youtube]6WMip0ZczeA[/youtube]
Offroader said:I think you take the word "best" to literally.
Rix knows better than anyone about unsprung weight, I don't think he would be saying a 3.5" tire was better without taking those things into account. I know we had discussions before about unsprung weight and heavy tires.
Driift said:Just mounted up a set of pro tapers Rc bend with carbon adaptor and riser stem . Really cool.
Driift said:Best tire is the Michelin star cross 5 medium compound. Lighter weight stronger more durable $98 shipped from
Motosport. Only drawback sheered valve stems. Rim lock or tubeless.
Stock tires are absolute crap. Wear too quickly and offer no real traction.
Nice parts about Sur Ron bikes .. customizing to your own tastes. Fun to do too. Just mounted up a set of pro tapers Rc bend with carbon adaptor and riser stem . Really cool. And not the stupid look of the 3” bars the 810 from pro taper. You look like a tool with those bars.
3DTOPO said:efMX Trials Electric Freeride said:best surron tires?? :wink:
I was expecting the video to try out and compare different tires.
But no, the only tires other than the stock tires he has tried he declares the "best". Of course they are better than the stock tires, but declaring them the best seems dubious.
Pretty sure a knobby tire would have performed better on the trails shown.
