Hey Guys,
I know this is a fairly loaded post for my first one, but here goes nothing.
FRAME
I am really interested in doing a Surly Big Dummy build. There are a few reasons why I chose this frame. I test road the UTE and it was a lot of fun and from what I have read, the BD should be that much better. This would really be a forever frame for me. It fits a segment that really can’t be much improved upon. I can load it up with a good grocery run, put my daughter on the back, or the whole family can even hop on if need be. I can even give a buddy a ride home from the watering hole down the street. The utility is endless and that is what I really need right now. I really respect the Xtracycle platform and I can see it being very viable for a long time. I’m sure that more and more manufacturers will jump on the platform and produce more add-ons for it as people gravitate to this as a more popular form of transportation.
NEEDS
Here’s where things get a little bit tricky. 75% of the time, I see myself riding on a 10-15 mile or less round trip, running errands, myself and maybe 50 lbs. of cargo, just cruising along. 12.5% myself on long trips alone that would be 20-25 miles one way with a few hour stop, then return. The other 12.5% would be me and another adult riding for a 10 mile round trip.
The terrain is fairly flat. There are a few hills here in Phoenix that can be a total nightmare, but they are not frequent routes. One very frequent route is only about 6 mi roundtrip with a pretty consistent 15% grade all the way there. Most of the time it is 5 miles out with a slight 3-5% grade home.
I would like this to be the cleanest build ever seen. The BD has that entire area behind the seat post and rear axle that is perfect for an ebike build. Because of my desire to build a stealth ebike, I would like a rear hub system that would be covered by Xtracycle bags. This keeps me away form the Stokemonkey type of chain drive builds that add another component to an indiscrete part of the frame. I want to keep the battery and controller out of the useful area of the Xtracycle system and keep it contained to that extended frame area or under the main triangle of the frame.
MY DILEMMA
I want to keep this bike for a long time. I want to use it for both exercising and cruising as an SUV. I want it to be half utility bike and half hot rod. I know what fast is (side note – my current bike is a FS Ti Titus 29er that I am going to sell for lack of use because of kid.) Because of the length of time that I would like to keep it, I would like it to be flexible as far as setup is concerned. The whole ebike/motor/battery industry is changing so quickly as technology progresses. Some components will become more efficient and cheaper due to advances in technology while others could become more expensive due inflation of material costs.
Here’s where the dilemma comes in. I really appreciate the cohesiveness of the 48V PL350 Bionx special edition system that is coming out. It seems like the easiest solution for my build. I don’t know what the range will be and I am concerned about the amount of torque that the system would provide for a heavy loaded scenario. I appreciate the fact that it is a canned solution that would fit neatly on the BD frame in the extended area in front of the rear tire. I really don’t like the fact that it is speed limited to 20 MPH, not because I would regularly go beyond that number, but because I don’t have the option to if I want it.
The Crystalite builds scare me because they seem as if they are expert systems. From what I have read (remember – not an expert here – just an impression) is that they are a good way to economically get a lot of performance out of a custom setup. Find a good controller and battery and you could tinker for the rest of your life.
I can’t find a lot of information about the ezee system. I have found references that say it can accommodate a high speed 48V system that is not top speed regulated but haven’t found much about it. I have also read that it is a high torque system that could help with the heavy loads and the hills that I am concerned with.
THE BUILD
I know that this is going to be an expensive project. I have identified and expensive bike and my requirements are diverse. It’s easier to cut costs when you want a bike that does one simple thing and does it well. This project is more complicated because I want a utility bike that can handle a huge load, but also be a little speedster when I want it to be. I am not concerned about local laws because I expect to build the bike in a covert way that will not divulge the fact that it is electric. I am willing to pay a premium for all of this diversity in performance in light of the fact that I will keep this bike for a long time.
OPTIONS
Talk to www.electriccyclery.com about building me a BD as they do already with the new Bionx 48V PL350 that comes out in February. It seems like an easy, but expensive option. I would also be top speed limited, but I’m sure that it would be a very clean build. I would be willing to incur the expense if this was the cleanest, best performing option that would satisfy me for years to come. I’m sure that I could find a way to overcome the speed limiting eventually.
In the same light, I could order the same Bionx kit and do a more custom build. This would give me a little more flexibility over other options but I would end up with about the same bike with a little more headache.
The thing that concerns me most about this setup is that it is a proprietary system that is not very flexible. It seems as if I would be tied to Bionx (which is a Canadian company that is far more regulated by the laws in Canada and seems more interested in keeping with the law than providing really high performance systems) and not getting the performance to dollar benefit that I could with a homebrew system.
The other option that I have is to have you guys point me in the right direction. From the examples that I have given you, you know that I am willing to pay for a dream machine that will give me enjoyment for years to come. I would appreciate the option to tinker with it and continually make it a better bike, but if the prospects of that are slim considering the speed at which technology is advancing and my aesthetic and performance requirements, I may be better off going with the canned system.
I am really interested to hear what all of your input is and appreciate your thoughts.
Thanks,
Trevor
FRAME
NEEDS
MY DILEMMA
THE BUILD
OPTIONS
Thanks,
Trevor
