Jonathan1981
⚡ Regular
- Joined
- Mar 29, 2011
- Messages
- 185
Motor is off a 2017 Surron LB with ~ 6K km's...
Long story short. One day throttle stopped working so replaced the throttle controller box. No dice. Figured it was a motor issue so opened up the hall sensor cover, seemed like the hall sensor magnet was not lined up with the line on the shaft (Theory is it slipped over time throwing off the timing). I pulled the magnet off, re-aligned it and re-glued it. Everything then worked but upon bench testing it, the timing was a bit off (Motor would spool up but then slow down at full throttle), so I just shifted the hall sensor board (The green slotted plate) a little bit until the throttle seemed to ramp up without issues. Rode it for one big ride and all seemed good. Went to ride it the next day and upon doing a hard pull under acceleration, it jolted, made a loud noise and then obviously stopped working, back to the same issue. The motor cogs heavily now (hard to turn). The theory was the glue I used to reglue the magnet melted or slipped, causing a miss alignment at peak torque therefore making thing go boom... however, upon opening the hall sensor cover again, the magnet and board all appear good, like I left them.
I've called motor shops around and surprisingly, no one seems to work on these motors locally. Just looking for some advice(from those more experienced with EV motors) on how to proceed . Ideally I'd like to be able to repair this vs. buying a new motor... if someone on here knows how to repair these motors, I would even be willing to ship it out for repair (Within US/CAN).
Cheers
Cheers
