gwhy!1
That seems to be pulling a lot of current to drive the gearbox! what do your motor pull when not connect to it ?
marcexec said:Tested that for you:
CA says Amax 8.25A without belt, 10.25A with, driving the whole assembly (minus front sprocket and what comes after)
The motor has the skirt bearing and the can is not 100% true either.
I might get some optimization with Burtie's TA still.
And also be aware that single cylinder motors are often side-split (hassle), while multi-cylinder are horizontally split. The old Yamaha 2 stroke electric start models have a HUGE space at the end of the crankshaft where the brushed generator/starter and ignition plate are housed. I think the armature weighs about 5 lbs.marcexec said:In retrospect, I would advise using a transmission that's sealed more easily like shaft drive or 2-stroke.
I will have more updates soon.
live peak max RPM
bypass 9.95
+15/0/0 ~8 9.60 5966
+10/0/0 ~8 9.00 5891
+10/-15/5000 ~8.4 10.09 6107
+10/-20/5000 ~8.5 9.89 6233
+10/-25/5000 ~9 9.80 6454
+10/-30/5000 ~13 13.03 7086
+5/0/0 9.48 5882
0/0/0 9.5 5819
-5/0/0 9.78 5927
-10/0/0 11.33 6131
marcexec said:So, drove it for the first few kilometers through the neigbourhood. Motor gets warm at the skirt bearing - most likely because because it's revving quite high in 1st gear, will remove that.
Also added the CA in the meantime, after building a custom bracket:
Test setting: 72V 14Ah LA test pack, controller at 35 A(batt), TA not fitted atm (no case) + sticky front brakes![]()
quite zippy when accelerating fresh off the charger, need to add more batteries obviously - 2.5C is too much for the small, (discarded) SLAs
marcexec said:Some more progress:
- added another string of 6 SLAs for a total of 72V / 28AH in a lower battery box
- did a quick beta test and took her out for a ride: the SLAs sag like hell, but I can get to ~50 km/h and the CA sees around 2kW :lol:
I can make a video if you guys want to see it...
marcexec said:I went and measured the space "around" the gearbox assembly and pulled the trigger on 12 Nissan Leaf / Renault Fluence battery modules. Source: http://hybridautocenter.com/HAC4/index.php?option=com_hikashop&ctrl=product&task=show&cid=3&name=nissan-leaf-battery-module-model-2012-new&Itemid=605.
That should yield ~6kWh and nearly 22kW constant power. Will have to re-tune for the higher voltage then
I should be able to mount them in 2 or 3 blocks and get some space under the tank for storage.
marcexec said:Discussed a little over at BVS (was originally looking for a share of a salvage one but not worth it):
http://www.batteryvehiclesociety.org.uk/bvsorguk/forums/viewtopic.php?f=3&t=3709
12 modules: ~1200€ at my door, no customs so far - 1 out of 3 to go.
BTW, a stack of 4 come in at ~135mm gross height as they stack into each other a little, maybe 2mm each.
