parabellum
Nice! Can you eventually share current closeup setup pictures? Motor part is the interesting one
parabellum said:Thanks! Nice work. Hope, you get it working. Would be interesting to see efficiency numbers.
P.S. What is the difference between Alien and Turnigy?(except halls)
gwhy! said:did you get to the bottom of the cutting out ?
also make sure that the kv are the same on both motors as this can also cause problems they dont have to be exact but ideally the nearer the better .. I know you have your halls mounted in the slots so tweeking the timing is not a option but this may be the problem with the cutting out.
gwhy! said:ok so in theory they should be the same kv.. I have never had any of my 80mm outrunners tripping a 12fet nor a 6 fet for that matter.. My sensors are external and can be tuned to elimiate the hardwired trip.. I think as you have wye terminated motors and if you have the sensors in the slots this my be a problem that will cause excessive high phase currents .. but I hope it will all be fine and Im wrong.
