I have a TransX direct-drive hub motor that came off a iZip E3 Dash that I would like to use as a generic hub motor, here is why that is not straight forward.
There are several threads about these bikes, including a couple of my own. This bike, and several other models like it have a proprietary system that incorporates a controller that is inside the hub motor, and it relies on a couple of external items to operate. Those include a bottom-bracket torque sensor, a proprietary BMS in the battery, and a proprietary display and handlebar switch. If any of these items go bad, you can't replace it with something generic.
With all that said, the one exception is the battery BMS, I have a running bike that uses an aftermarket battery, but without the original BMS the display does not show the charge state of the battery, which is easy (for me) to live without. I have an extra wheel, and I'm fond of the quietness, reliability, and power of wheel on my working bike, but I don't see the value in keeping this extra wheel as a spare, for several reasons I won't bore you with. On to the project at hand...
I popped the cover on the wheel to have a look inside, see image below. I think I've located and labeled the main things that need to be dealt with? What little I know about making the conversion is, the hall and power wires will need to be able to exit the same hole the current data and power cable goes through, but I think I can make that happen. Where my knowledge falls short is, I'm not entirely sure what, if anything, I would need to do with the thin wires that go from the circuit board to the stator (see arrow with question mark), or if there is anything I'm not seeing and haven't labeled yet.
Note added 8/8/2025: The original image has been updated/corrected after receiving the feedback provided below.
Any and all insight is much appreciated.
