gwhy!1
I have been side tracked on the final testing for the controller ( but I am waiting for some more fets to arrive anyway) BUT I have been making a stand alone throttle interface for it which I think would be a very good addition for any controller, so far the interface has a throttle lockout i.e on power on, the controller e-brake must be on ( can be a small switch on handle bars ) while the e-brake is on the interface tests to make sure the throttle is at a minimum setting, if the throttle is not at its min it will then hold the e-brake line low and also disable the throttle output even if the handle bar switch is turned on ( throttle lockout & controller disabled on fault ), There is also a 2 position switch for the 'mode' of throttle response position 1 (default) doubles the resolution of throttle i.e min to WOT =50% speed this also uses a momentary switch on the left handbar that when pressed changes the resolution to 100% speed ( this is just the same setup I have been using on the little standard 6fet controller that I have and it works a treat), position 2 of the switch puts the throttle into a log output mode i.e very fine control over the first half of the throttle range but ramping the resolution down the nearer you get to nearer to WOT ( this is what is really useful ) . The interface also sets it self up for use with a hall throttle or a pot throttle ( so no padding resistors to mess about with). I have only just finished the prototype and not fitted it on my bikes yet but on the bench it works very well but a little more testing to do.
So the question is can anyone think of anything else that might be useful to program into the interface ? . Also if anyone is interested in having one let me know as I was not planning to make extras but if peeps would like one I dont mind making a few extra when I come to finalise it.
