sn0wchyld
gwhy! said:Spacey said:@Planky Maybe it's this controller then as it did this with the 9C I had and Beavinator had the same problem with his HS3540. Anything above 35amps and it loses sync really bad so I have to feather the throttle. Once the volts go down by a volt or two then it gets a lot better. Not sure if mine is a mark 1 or 2, have had it over a year now.
@gwhy! Sorry I meant 16S my fully charged voltage is 66.2v. I charge to about 4.12v and discharge to 3.8v on my 17.4Ah of Lipo and still apparently have 40% left in the tank. 12 mile WOT ride with a none modded HS3540. Think I will drill some holes in it like the 9C.
66.2 volts is still boarder line for 75v fets I know on paper they should be fine and yes you could probably get away with it with a hub motor , OK I will keep it in mind when the time comes![]()
Yea I'd be less interested if I could only run 16s. Just ordered one of those huge 5404's, and was hoping to run it at ~100v....
