Hi all
Could I get some help with my temperature sensor?
I have a qs273 motor with the KTY83-122 temp sensor. I want to read the temp through the CA because I can't read the temp through the controller. I came across these 2 charts in order to program the Linear settings.
The KTY83-122 has slightly different numbers on the charts. Which parameters should I use? Thanks
endless-sphere.com
endless-sphere.com
CycleAnalyst CA3 and temp sensor connections
Hello all, I am busy building my new project bike and have a question. Motor is 5kw rear hub with 2 x hall and 2 x temp sensor wires. I don't know if the temp sensor is 2 x in the motor, or if there is just one with 2 x wire coming from it. I am using a SMVC96120 controller. The controller has...
Cycle Analyst V3 preview and first beta release
Thanks for the clarification tek!
