MrDude_1 said:
okashira said:
I think the power stage should be exactly the same for induction vs bldc vs pmac.
The only difference is the angles you introduce the current: magnetizing current is needed on the D axis and measurement of the rotor flux angle is the same theory too.
I guess they may not even use an encoder? since they can set the rotor flux angle when the car is stopped.
The magic is in their brain of course, Tesla probably has the best induction motor logic out there. Torque sleep (their term for controlling rotor flux strength) is not easy to implement for EV application because of the throttle lag it would create if the rotor flux is too low.
The Tesla motor has an encoder.
I guess most of you have not read this... http://ecarproject.ch/
This guy not only has the Tesla motor running on its own inverter.. he can run any of the major car companies inverters, on most of the other motors.. you could turn a model S motor with a chevy volt inverter for instance... or a prius drivetrain.. etc.
Of course, because the power stages are basically the same
I am sure his ACIM logic isn't as good as Tesla's
The prius motor is IPM, which you could run... with any BLDC controller but to run it right the ideal phase angle is different and is a function of torque and speed and needs to be tuned for the specific motor.
