okashira said:
Tesla is already pushing their motor to more power in kW/kg out of any EV.. And it's not because their motor or inverter technology is any better then anyone else's
I reckon it must be related to the thermal limits of their system. Here's a few cents bearing in mind I design IPM motors, I'm no more than an interested observer on all other aspects:
* in my EV designs the electronics must be sized for peak power, not average power because the Si dies get to max temp right after the max current passes trough them (Cth=0); electronics have no thermal inertia
* Tesla have an Induction motor. My own PMSM is 14kW/kg and its biggest issue is rotor temperature because you can demagnetise (200°C limit more or less for Samarium). Tesla doesn't have this problem because they have a squirrel cage induction motor - I have seen these at 350°C rotor temp, while an IPM on Neodymium like the Prius can't really go over 140°C.
*** ==> on the other hand one can't keep the rotor at 300°C for a long time as it will radiate heat to the stator where the usual limit is around 180°C (insulation usually); as such I can see the Tesla going nuts briefly, after a while you'd do some power derating as the rotor heats up.
Another limit I know of in motorsport batteries is inner-cell temp for batteries ==> again you can go nuts briefly, but heat dissipates from a cell only thru the tabs and to the water sleeve, you rarely find fully liquid-droned batteries due to weight. In this short period the inner cell temp rises from maybe a normal 60°C to 80-90°C (I know of A123 heavily power-modded LiFe); it's only the thermal capacitance of the cell that allows the burst as thermal dissipation is limited through something as small as the tabs.
So my 2 cents would be that we could tune the Tesla easily if:
*the cells aren't at the temp limit with a simple bypass of the DC current sensor and/or fuze
*or if we'd cool the rotor; that's tougher because bigger rads to cool water more would mainly cool the stator, the rotor would heat up just as fast. I only know of 2 ways to cool a rotor: lubricated bearings and forced air cooling in the airgap. Forced air should be easier - during a a drag race one could add some liquid nitrogen in the air mixture to help with the cooling too
