tikivic
Elegant solution Mike. Mine is decidedly less elegant, I moved the axle all the way forward, and machined a spacer that goes behind the axle secured by the pinch bolt. So of course I have no adjustment for the chain tension, that is handled via the Rohloff chain tensioner. I am curious if (why) you require the adjustment (i.e. motorcycle) and if so how you get around the chain growth on the Raptor as the suspension moves?
V.
V.
LightningRods said:My chain tugs arrived. They are almost perfect as delivered. I had to relieve the front of the raised boss that rides in the dropout slot, and I had to widen the slot on the adjuster nut bracket to accommodate the unusually wide Qulbix dropout:
I was able to make those mods with an angle grinder and a flat file. With those two changes the tug fits like a factory part:
This should positively keep the axle from sliding forward under power.
