Hi Gary,
GGoodrum said:
What does circular braid look like? None of the links you posted had any pics.
Search for Belden Tubular Braid.
http://www.takefiveaudio.com/mall/shopexd.asp?id=289
http://cgi.ebay.com/Belden-cable-ti...und-strap_W0QQitemZ280317900916QQcmdZViewItem
Buy It Now price: US $7.99
2 - 18' pcs. of Belden cable tinned copper tubular braid approx. 5/16" diameter. The looser braid is expandable up to about 1/2". You'll get one 18' coil of each type braid.
GGoodrum said:
Mitch, the problem is what do you rivet the springs to? There are pretty big holes in the end caps already. For the middle 10-cell blocks in the pack I did, I put the copper strip in between two end caps, and had the springs go through these holes.
Off the top of my head I can think of two or three options:
1. Use big washers on the other side of the plastic caps.
2. Use a piece of plastic or two strips of plastic on the other side of the plastic caps.
3. Rivet bowed washer springs or slotted cup washer springs directly to the copper straps. They should be much easier to fasten to the strap than regular coiled springs.
GGoodrum said:
I need to do another couple of these 16s5p packs, but I really dread having to do a whole pile of the copper strips and springs again. I'm definitely going to look into some sort of compressable braid or tubing. That could save a ton of labor.
I have some misgivings about the braid. First the amount of compression is very limited. Second the braid will tend to compress rather than spring.
I think you have come up with a very good solution. Using the end caps, bolts and springs are all excellent ideas. The result is excellent. I think if someone can figure out an easier way to use some kind of spring in conjunction with braids or straps that will be the best solution.
I like the idea of springs fastened to the caps, pushing something flexible (braid or thin copper strap) directly against the cells. I also like the idea of pop riveting springs directly to the plumber tape (copper straps with holes). I think straps (if someone figures out an easy way to use springs) will be easier to work with than braid.
