JB_EB
Hi all, sorry for the long post, but I'm looking for some advice for a temporary charging solution for my pack while I wait for Gary to produce the next batch of kits of the new BMS. I have only recently got hold of some a123 cells and I don't want to kill any cells through mistreatment from lack of knowledge. I have also bought a new 27V - 30VDC, 5.6A Power Supply specifically for use with the new BMS, so I don't want to have to buy more stuff if I can help it.
My existing 24V, 10AH LiCo battery pack has only lasted 14 months. I think the peak current draw of about 20A from my Cyclone 370W motor has caused the internal resistance to increase to the point where the pack can't deliver more than about 8A and that is with big voltage drop.
I need a solution now, so I can continue to commute to work...
I have a commute to work of 6.5km each way and I can charge at work. The 10AH LiCo pack (when new) would give me a range (until BMS cutoff) of about 20km. So, each direction of my commute produces a DOD of about 30%. Therefore, I'm hoping I can just use an existing power supply or SLA charger to charge the a123 pack for my commute for a month or so without killing any cells.
The cells were extracted from "warranty return" De Walt packs. All the cells I kept had resting voltages of over 2.95V. Most were at 3.31V. I have individually charged cells to a common 3.31V and have made up a pack of 8s5p (~26V, 11.5AH). I have individual wires coming from each 5p block of cells. (Other posts from Gary et al indicate that cells that have not been discharged below about 2.5V should have full capacity.)
My plan is:
Charge pack up to 3.6 x 8 = 28.8V.
I can use either:
a. The new 5.6A power supply I bought to use with the BMS (27V but I can adjust up to 28.8 or 30V in the future). This supply will overcurrent limit to about 5.6A.
b. An existing 2A 24V SLA charger (CCCV).
During charge, monitor the pack voltage with a multimeter. Also, monitor individual 5p block voltages. I will also use a simple mains timer to turn off charger within a set time based on initial monitoring.
Every weekend, I can "manually" charge individual 5p blocks with a variable power supply (~3A) to keep them in balance if required.
Given the short commute, do you people think this will be a safe way to do things for a month or so until I get the full BMS / LVC kit?
Any advice greatly appreciated.
Thanks,
JohnB
My plan is:
I can use either:
Thanks,
JohnB
