What it would cost to do a basic EV conversion with these specifications?
100 miles range
And a top speed of 60 mph?
Since the bulk of the cost is in the batteries, and the others are pretty fixed, I thought that it'd be pretty straightforward to estimate. I've heard figures of 150wh/mi which would then need a battery with 15,000 wh. With the use of a super-duper-capacitor array that might run about $3000-5000, you can avoid cell degradation that accompanies high C current with accelerations that'd largely run off the capacitor array and then be able to operate with cheaper LiFePO4. I'd guess that "quality LiFePO4" that'd work for this capacitor bank might run $1.50/Wh which is only $22500. Toss in 5 grand for the battery, motor, controller, and BMS(or consider 10-15000 with labor) then it'd only total up to..
22500 - battery
5000 - capacitor bank
5000 - everything else
32500. That seems fairly feasible, doesn't it considering the average consumer spends ~$20-30,000 on a car? If you're to convert from a cheap high-mileage but "classy/sporty/desirable car", then a desirable electric might only cost 42500.
Is there something wrong with my calculations? Can it be done cheaper with something that could probably get at least 7-years/100,000 miles of service with greater than 70% of original range assuming 15,000 miles per year?
100 miles range
22500 - battery
