I wouldn't be suprised if plenty of folks here had/have hogs or crotchrockets... I sure did.
I gave 'em up before getting maimed or vegitated. Motorcycles aren't that dangerous, traffic and young riders are. (Ask any nerosurgeon or racer...) Here in Michigan, we call em'
donorcycles.
Onward...
Good research follows from clearly indentifying the scope of the inquiry...
Maybe good framework for the question is: "what
kind of performance and effiency can be achieved within legal guidelines for ebikes, given the available technology?"
And how do you define and where do you measure performance and efficiency?
Just like you can bore-out cycinders to get greater power frome a gas-motor, you can boost power from an electric motor... the trick is, what are the sacrifices?
The need for air cooling (when boosting a small motor) indicates losses in the form of heat... lots of heat = lots of watts not going to the pavement. But, you do get more performance in the form of power to the pavement, but you also drop efficiency with the heat loss.
On paper, gears are very efficient in delivering power to the road, but in the real-world, performance losses result from shifting gears (especially on hills?). CVT might be good...
On the other side, hub motor design currently seems to be applying the blunt-hammer approach: more power... despite the fact that they are turning the wheel from the worst place: the center of the wheel. A motor built out by the rim could have a smaller power rating but still deliver plenty of torque to the road with higher efficiency.
For what it's worth, you can't get much dorkier than me on a kid's electric motocross bike, but I take pride in not firing-up the ol' five cylinder just to make an in-town trip. Like you said, dorky can be an asset: a 5KW hub motor on a Barbie stingray could very well be the sleeper of day.
Don't forget the tassles...
