xyster
Well hell's bells man, are you planning to ride around in a tuck all the time? No wonder you're worried about speeding tickets and attracting police attention.
xyster said:Well hell's bells man, are you planning to ride around in a tuck all the time? No wonder you're worried about speeding tickets and attracting police attention.
TylerDurden said:Don't foget yer helmet...
Geebee said:Safe, you are in for a real shock when you fit a shell, a tuck is no replacement for true streamlining, your speed will skyrocket and current will plummet at the current higher speeds.
Lowell said:Does calling people here 'dorks' make you feel better about your low powered gear motors?
safe said:Lowell said:Does calling people here 'dorks' make you feel better about your low powered gear motors?
I know what real speed is and even the high wattage hub motors aren't that impressive. My point is that one should be HUMBLE with their small motors and enjoy the pleasures of getting the most out of them. (that's the fun part... squeezing efficiency out of little motors)
Raw speed is for young people with healthy organs to donate... :wink:
xyster said:With these no-wind, fantasy-case stats you've conjured, why people buy these stupid hubmotors, or want more than 1 horsepower, is beyond me.
Geebee said:...the real human speed record ie. pedaled upto speed on the flat with out a tow/draughting car is over 80 mph, in a streamliner. The upright bike record under the same conditions is a lot, lot lower.
safe said:xyster said:With these no-wind, fantasy-case stats you've conjured, why people buy these stupid hubmotors, or want more than 1 horsepower, is beyond me.
Actually, my "real world" bike was calculated to go 46 mph and I've done that, but some question of how perfectly flat the area was would call into question it's validity. Since my current "real world" bike doesn't have a fairing yet I can't expect the full number on it. But that online calculator is pretty accurate. These results are very real !!!
Think of it this way...
I'm trying to design a Honda Civic (the sporty version) with the little engine and gears.
You have designed... "A tractor" that can't go as fast as the power suggests you might, but it's solid as a rock.
Two different design ideas... both show up EXACTLY in the numbers as being correct as designed.
(or as the other guy said: "The Hub Motor is like using a bigger hammer")
Lowell said:Not having pedals definitely makes a big difference in aero drag. Our local regulations only state that an e-bike requires pedals that are capable of moving the bike. I wonder how they would feel about someone replacing the crank arms with tiny arms ending in foot pegs and a small single speed chain ring or belt drive that's just enough to make some noticeable motion.
Mathurin said:Stands to reason, if you're using the same motor (say a 500w hub motor)
in both direct drive and geared applications, the direct drive version will
get better eff then the version with a transmission in at least some conditions.
Eg: 19/20th of the time when I'm using the motor I'm going at top
speed, around the 20mph legal limit. Getting that speed through a
transmission would be lossy compared to getting it in direct drive.
safe said:Lowell said:Not having pedals definitely makes a big difference in aero drag. Our local regulations only state that an e-bike requires pedals that are capable of moving the bike. I wonder how they would feel about someone replacing the crank arms with tiny arms ending in foot pegs and a small single speed chain ring or belt drive that's just enough to make some noticeable motion.
The laws here aren't specific about pedals, they are more concerned about power limits. (and even there they are willing to allow 2 hp) The biggest reason that pedals cause a problem is that it means you can't place the battery pack where a "gas tank" would go. You are forced to put it on the back (usually) and that distorts the balance badly enough that you really can't go fast without handling issues.
My bike actually feels smoother the faster I go because it's balance is near perfect. (the weight needs to be a little lower in the back however)
So pedals are a big factor...
