dirty_d
DC brushless direct drive hubmotors are efficient and can be overpowered without burning up because of their mass, but they are only efficient at a narrow rpm range the same as all permanent magnet motors. so why not use gears with them? mount it in some way where the axle is fixed and the sprocket is replaced with a fixed sprocket, you run the chain from one of the gears on the motor to the rear wheel with a derailleur. you can install one of those freewheel cranks for tandem bikes and run a chain from the crank to another sprocket on the motor. the hubmotors are already designed to run at a very low rpm without any gearing so the mechanical losses in the chain will probably be the same as in a regular bicycle and also be very quiet. id like to do this to my bike but im not really ready to spend $200 on a hub motor.
