safe said:
You catch us all on a technicality... okay.. it was a cute idea...
Hello again.
Not a "technicality" and not a cute idea,
The matter is that the NuVinci (or other CVT transmission) does not create shocks to the system.
The electric motor armature or rotor has vast instantaneous -force-.
A step-shift, such as by conventional gear hubs, make an instantaneous change in gear ratio, requiring either a spring-buffer (human legs are that), or a slip-clutch of some sort, OR we must back off the motor power, at the least, for the shift.
The NuVinci wouldn't need any babying; needs no extra operation steps,
it would just be velvet and efficient and kindly to all of the parts.
That's the essence here. All other discussions, such a "no need for gearing with PWM power" beggar the point. We were speaking of mechanical torque conversion for ebikes, not electronic.
But yeah, OK, if you guys think the "torque multiplication" of PWM powering is equal to, or better than, mechanical torque conversion,
I am looking and listening, yet unconvinced on that point's superiority
as it might apply to my currie/Unite powered bike.
I do know that my PWM controller with 36V will slog the bike up pretty steep ravines at the local sinkhole park
...and draw
30+ amps in doing-so.
And this is fairly termed
lugging a motor at near-stall speeds.
And it has no back emf to speak of at such low rpms. And it sucks current
and heats like mad.
But if I gear down like we would for a -manual bike- or an ICE engine,
then the motor is free to spin and be happy holding back some of that current, while still developing HP -by the usual means-.
My little gearmotor needs to spin to be both a billygoat in the sinkhole park, and a 25mph road warrior;
it simply requires changeable drive ratios for the real world of mechanical drive.
It is all, after all, mechanical and simple. It's not an X5 or other such big motor. It's a buzz motor, whereas the big BL hubmotors are like 16 cylinders in comparison.
PWM torque conversion 'magic'
may work better with them, than with this tiny brushed motor. See, I only concern myself for now with what I have (a modest, cheap, Unite motor), and how to best exploit its capability.
The NuVinci drive, for my needs, is clearly the path to explore.
I hope the Fallbrook people reply to my inquiry with good news regarding a tandem-input NuVinci:
"yes it can be done...and we'll do it in time."
I won't hold my breath.
