This is a big topic that a lot of folks deal with. Minimal space between your swingarm and brake rotor. I know QS has a brake rotor spacer which I have on order, not sure when it will show up.
But I’m curious how others mitigate this situation? The newer motors come with this extra thick wire cover compared to a few years back when they had a more pliable sleeve.
I’m running a standard 4T 205 and a enduro e-bike kit frame from NB with the 150/55mm drop out option.
Everything fits great but those motor wires are extremely close to the rotor. I countersunk the rotor and bought some stainless steel dishes screw which helped.
Do most people just zip tie the bell out of this? I was thinking about using wire tie like what you see to secure fasteners and things. Slip it through some thick shrink tube so it’s not going to cut through the wire sleeve and then twist tie it to the swingarm. It could be pulled much tighter than a zip tie.
I think the spacer I have on order will be key but those are seemingly harder to find.
