On a standard e-bike, you can get to 30 mph with 700 watts output power. Now reduce the the usual cross-sectional area by 3 to get a bullet-like enclosed recumbent and improve the coefficient of drag by a factor of 5 from the usual Cd=.9 of a bike, and this enclosed recumbent requires roughly 15 times less power to go the same speed. Since P ~= velocity^3, then going 70mph only requires 700*(70/30)^3/15 watts(Original_power*transformed_ratios*any_relevant_ratios) or about 600-700 watts (or <1000 watts for generality) with the stream-lined bullet enclosed recumbent. Add in a 3000+ watt RC motor with the proper gearing, and you got it made! Assuming fairly flat travel between two points, your standard 40 mile battery can now go more than 100 miles(well... that should be calculated). Couldn't you get somewhere on the highway system with that set-up?
