adsc
⚡ Regular
Lol, the potato chip bag thing is awesome, proper omnissiah machine cult behaviour.
I'm willing to bet the HE cell uses a sodium metal anode (anode-free), so the voltage curve should be quite a bit better.Wow, that's high enough for me to want to trade safety for that big sloping voltage curve it has.
How is balancing possible? Will all the layers stay the same voltage all the time?So this is a bit interesting, assuming they didn't fake it by wiring cells in series inside a pouch cell. Video shows how they can build cells at different voltages. Each layer would be .55V if the graphic is accurate.
Balancing is possible because everything is matched from the factory and thermals are essentially identical.How is balancing possible? Will all the layers stay the same voltage all the time?
This not correct. What you want to say is "balancing is not needed". Not that it is "possible".Balancing is possible because everything is matched from the factory and thermals are essentially identical.
Bi/multipolar cells are the holy grail of pack building since they make stuff so much simpler, higher performance and lower cost.
Agreed.And even this is not correct: You still could have small differences in size, loading, porosity of the electrodes etc. resulting in differences in capacity, finally resulting in debalancing of single electrode stacks. Further thermal imbalances could still occur.
"There is no lithium"Agreed.
Then there is the varying loss of lithium from electrolyte-electrode interphase layer formation in each cell element, also affecting capacity. Minimal, but there.
How it wont help? In a pack if you have a weaker cell with lower capacity it will be the first one to reach 4.2V and also when discharging will be the first one to reach 2.5V. Therefore the weaker cell gets more cycles and becomes weaker and weaker and at failure it looks like a single cell sudenly diedsame for bosch. seen some unbalanced packs which died because of single cell failure, but balancing wouldn't help.
Good point! I screwed up, thank you."There is no lithium"
There's a lot of tool packs like DeWalt, Milwaukee, etc. that get away without balancing for years. So it does seem vaguely possible to do without just by matching the cells well at the factory.
yeah, and now think, how balancing would help, or not. the weakest cell will get the most stress anyway.How it wont help? In a pack if you have a weaker cell with lower capacity it will be the first one to reach 4.2V and also when discharging will be the first one to reach 2.5V. Therefore the weaker cell gets more cycles and becomes weaker and weaker and at failure it looks like a single cell sudenly died
If we talk about passive balancing then yes passive balancing will punish the weakest cell even further, but there is active balancing alsoyeah, and now think, how balancing would help, or not. the weakest cell will get the most stress anyway.
Those packs have tons of issues with early deaths so even with great matching you will have problems, but they do last longer than you'd think.There's a lot of tool packs like DeWalt, Milwaukee, etc. that get away without balancing for years. So it does seem vaguely possible to do without just by matching the cells well at the factory.
Of course, those companies profit from the packs dying earlier than they would otherwise and the customer buying a new one. So it does sort of fall into the planned obsolescence category more than forgoing unneeded hardware to have more room for capacity category.
This is only true if the root cause of debalancing is varying capacity (either from the start right away or due to higher stress on one cell for whatever reason) among cells. There are also other reasons for debalancing like different temperature, different resistance or different self-discharge rate of cells. For the latter cases, balancing helps a lot to prolong the life time of a pack.yeah, and now think, how balancing would help, or not. the weakest cell will get the most stress anyway.
There’s been an almost constant stream of new 21700 releases for the past couple years and a few 18650 releases too. And several of both in the works too.Anything new from the 18650 and 21700 world?
How they deal with overcharge? Isnt that a fire risk? A big disbalance can cause one of the cell to go over 4.2VThe last power tool batteries I bought did cost 15€ including a charger. (Einhell 18V, 2,5Ah pack).
There is no point in adding a 50A BMS with active balancing to that
For example the Molicel P30B is available. I assume it is roughly comparable to the P50B in 21700 size. Molicel has a roadmap for future 21700 cells up to the magic P85, but I don't know about something comparable in the 18650 size. This is the same with all manufacturers. I use the LG MJ1. This cell is from 2014. Still nothing newer here?There’s been an almost constant stream of new 21700 releases for thr past couple years and a few 18650 releases too. And several of both in the works too.
Ampace JP30p1, EVE 30PL and TenPower 30XG are all amazing 18650 power cells with 3000mah nominal ratings. Ampace and EVE cells look to be pretty widely available.something comparable in the 18650 size. This is the same with all manufacturers. I use the LG MJ1. This cell is from 2014. Still nothing newer here?
As I mentioned, many….too many to list here.Still nothing newer here?
