Three pin small connector
Kyokushin
Established
I am looking for the connector from the photo. Anyone know what is the name of it and where to buy male and female?
Photos comes from Luna, they're wrote its mini XLR but it doesn't look like mini XLR.
I found it also on ebikes.ca described as 'small 3 pin connector'
https://ebikes.ca/learn/connectors.html
I just went through similar... I bought a Super Shark battery from EM3EV 2 in 2019 that came with that "other small 3 pin" connector. I still don't know what the name of it is nor was I able to find a source. I got another battery from EM3EV 2 months ago and it came with a similar but different enough ST3 connector which seems to be more common these days. So I opened up the old battery and changed that one over to a ST3. Bottom line is I have abandoned that "other small connector". Let us know of you find out anything about it.
I found something
https://www.greenbikekit.com/accessories/e-bike-lithium-battery-parts/jumboshark-supershark-3-pins-charging-cables.html
That's it... good job! Reention makes sense I believe they are the case manufacturer.
Kyokushin said:
I found something
More found here:
https://electricbikereview.com/forums/threads/reention-newly-upgrade-48v-25ah-36v-30ah-505l-interchangeable-for-ebikes-surface-604-ncm-rize-magnum-aventon.42705/
Its called just "Reention 3 pin" charging port.
I know I see three pins but I think there was just a negative and positive for charging if not the other one would be a thermal pin ?
by the way I always check for continuity you never want to hook positive and negative unless if you like meltdown effects.
Gen kuya. That's the way it came out talk to text. HaHa.
The third pin on these and the other 3 pin charging connectors that I have seen are never connected to the battery. When you open the case only + and - are connected. The battery BMS controls the show for protection and such.
