Thumb Throttle
Portugal / Europe
Hello crew,
Wen I bought this controller from High Power Cycles and motor, it come with a half twist throttle. It work well, but I do not like it, and want to use a tumbe throttle but can not put it to work. Is it possible ?
Thanks for the help.
Three wire throttles use a hall effect sensor. One wire is usually ground, one wire signal, and the third wire +5 volts. Your twist throttle also appears to have controls for power on, high, and low. You probably need something like this to replace it:
48v Led Thumb Throttle (Right)
Bought one. Thanks.
