Doctorbass said:IS it possible that due to the angled tooth of the stator, that the X5 serie wont work?.. just like for the Delta-WYE...
The X5 had no succes with the ( electric transmission) Delta-WYE and it just consumed more current.
I see the exact same problem here but about timing.
I guess taht with the 9C, HX andcromotor it would?
I was expecting it to qork with my X5 and the $$ Enertrac that my friend J-L bought but both are angled stator tooth :?
Well... I will try anyway on both
Doc
thats an interesting question doc,
the x5 has bugger all poles, and clearly an non sinusoidal waveform.
the low pole count means theres a lot less erpm and way less timing advance needed/less advantage from it.
the angled stator tooth is just one way in the motors design of changing the waveforms shape, and if it was sinusoidal then it would work nicely in delta cos any phase has the same instantaneous voltage as the others add to. -resulting in no circulating currents, and no losses.
-if it does not play nicely in delta, then there may be something in that , and it would be good to see the x5's shape on a cro??
