Toseven DM02 chainring play issue.
Hardingen
🧲 New user
Norway
Hi. Wondered if any others have issue with chainring play on Toseven DM02 or 01. Pretty sure it was very little play when new. I have two chainrings and derailleur, so with the play chain is rubbing a little bit. The axle that holds the pedal has no play, except sideways which is normal. But the assembly with the big gear and chainring mount has play. I replaced the small bearing between axle and chainring mount(16.30 in this video,
), but that was not the problem, same play after. So if someone have had this issue and fixed it, let me know please. I tried Toseven, but got the : I have to tighten the chainring nut answer, among other likewise answers, so have given up on that.
How about a picture of your setup ? That would help assess the problem...
I can probably post a picture, but the problem is inside the thing. But it could maybe show part of the cause of the problem. Like a big 52 ring a couple of mm outside of the original ring. I guess I`ll ride it until complete failure before doing anything more drastic.
