nicobie
If you do decide to carry your bike in the back of a pickup or van try not to flop in on the derailer side as it will bend the derailer bracket for sure. I found this out the hard way.
calab said:Would a heavy heavy guy like chalo put much faith in folding pedals?
Be something in the back of the mind to not think about while riding for a guy like chalo.
nicobie said:If you do decide to carry your bike in the back of a pickup or van try not to flop in on the derailer side as it will bend the derailer bracket for sure. I found this out the hard way.![]()
dogman dan said:The motorcycle carrier should work good for one bike. I just did not mention that because I haven't used one yet. Trying to talk about things I have actually done here. About same cost as a swagman carrier.
I like my tri fold ramp for the truck, from HF. I can ride up it, but walk the motorcycle back down it. So you could walk the bike up it under power. I don't like the idea of trying to ride down a skinny ramp backwards.
You sure that wasn't the clutch lever?gobi said:I watched a moto guy do it, he held the brake lever with one hand and walked the bike up with throttle,
99t4 said:You sure that wasn't the clutch lever?gobi said:I watched a moto guy do it, he held the brake lever with one hand and walked the bike up with throttle,
pullin-gs said:Have not completed it yet, but this is my setup:
Using this 22x60" aluminum hitch carrier:https://www.amazon.com/dp/B07QKGS149/?coliid=I2MBVE3V61N0BN&colid=H89155HI0080&psc=1&ref_=lv_ov_lig_dp_it
Wheel chocks are bent #4 rebar. Center post is 2x2 steel bar. Uses tie down straps.
dogman dan said:Well, actually, what your truck needs is a lift tailgate. Pricy. But if you are driving a balloon chase truck, you may as well have the lift gate on it, that every balloon truck needs.
Downside, EVERYBODY will want you to help them move. So if you buy a liftgate, you better get the appliance dolly too. :lol:
Seriously though. If you have that much truck, you will never regret putting a lift gate on it. If you have the really old truck, the gate can be found used for fairly cheap. Newer trucks need a narrower one. But the gates out last trucks, so you might find one fairly cheap, even if your truck is only 10 years old.
... but you can put more of strain on the pedals than some of us that have a somewhat lower affinity for the earth's gravity.Chalo said:I've broken regular pedals clean off of my bikes a few times, so I try to discriminate.
Thanks for the suggestion. Noted.calab said:That is pretty cheap with free shipping. I wonder how sturdy it really is, you might have to beef it up.
pullin-gs said:Thanks for the suggestion. Noted.
I would not use it for 500lbs. Both my ebikes come in at around 1/3 of carrier's maximum 500lb capacity.
1200 reviews, 3% are one-star. Of those not a single failure....complaints mostly quality control issues.
dogman dan said:New lift gate is not going to be affordable. But as time goes by, you might look for used ones. You'd get one from a junkyard most likely. Really nice to have a ride up into a truck bed that high, whatever you may carry. Superb way to load dogs, by lowering it halfway to make a step. They also make lift motorcycle carriers.
Not as hard to install as you might think. Place the gate on the ground with it lowered and connect to a battery. Maybe a bit of weight on the gate. Then working the gate will lift the mount up to where you can back the truck into it. A few holes to drill and a few bolts, but nothing too hard. Then you just need a large wire from your battery back to the gate.
dogman dan said:I learned while I was doing a lot of windsurfing, that you should double up anything tying shit down. So that meant a third bungee in the middle for that.
For the bikes on my rear carriers, It had a ratchet and hook that clamped down the bike easily. But I'd back it up with bungees on the wheels.
I'd strap your bike down with ratchet straps into the carrier, like you would a motorcycle, then bungee the wheels to the carrier. It would suck to drag a bike that came loose, but it would suck more to send it into somebodies windshield.
slaphappygamer said:This is what I use.
https://www.amazon.com/gp/product/B004RFKBEO/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
I can load my Ride1Up 700, a RadRunnerPlus, a kids 26", and a 16" kids bike. It handles the weight well. The RadRunnerPlus has 4" tires that didn't fit into the "braces" that strap to the tires. Another nice thing about this carrier is, I can load other items instead of bikes, like coolers, or wood. Dual purpose things are the best things.
