TranzX battery BL07 wiring schematics from a 2014 Currie Izip E3 Path+
Biokinetics
🧲 New user
Florida
Hi all,
Does anyone have a TranzX battery BL07 wiring schematics?
I have a 2014 iZip E3 Path+ that I just got, knowing that it needs a new cell pack.
However, there is a small 2-wire secondary connection between the battery and controller that I have not been able to to identify, I suspect it may be a lower voltage feed, but it could be a switch wire or ???
Does anyone have schematics for this battery?
And/Or for the whole system?
Battery is definitely bad, smells like Magic Smoke, and the cells look like they are seeping under their skin!
I realize that this is a dinosaur, but other than a battery that was a bms failure away from a structure fire, it is like new.
Thanks! 😎 🙏🏻🙏🏻🙏🏻🤞🏻🤞🏻🤞🏻😁
Hello Biokinetics, were you able to determine the purpose of the secondary connections? If so, what is the purpose?
